Hi guys, removed my rear wheel with no trouble, but can't get my front wheel of as it seems to be a special tool required to get the spindle out, it looks like I need an inverted hex head opposed to a socket? Am I being a total idiot & missing something simple here? Cheers.
Lachie
Front Wheel Removal
Geffro
- My Bike: ZXR400 L1 trackbike
Front Wheel Removal
Lachie Innes #99
- My Bike: zxr 400
Re: Front Wheel Removal
You'll need an allen key, cant remember if its 12mm or 14mm though
Geffro
Thanks mate, just need to source some big Allen keys now! Cheers!
Lachie
Lachie
Lachie Innes #99
use a bolt with a couple of nuts on the end acting as locknuts and a spanner
parby81
- My Bike: ZXR400 L9
or order them off the internet, places like tooled-up.com sell them. 14mm and 12mm i think (different on either side) but i'd have to check, give me a shout if you need me to.
masterofinsanity wrote:use a bolt with a couple of nuts on the end acting as locknuts and a spanner
This doesn't always work especially on an axle that been in place for months on end..................I made one for my ZX6 and welded the locking nut on...............even that broke.
So I bought one of these....................and I strongly recomend them.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWNX:IT
This was the cheapest on ebay and the quaility while not Snap On is still very good.
I've not found one of these in the right size for the 400 but you can get hex key scockets in 3/8 and 1/2 drive sizes so you can use your ratchet
Two ways to do this.....................
A 14mm hex key will fit and remove the spindle itself leaving the "nut" in place. ( It's not a nut but it serves the same purpose)
A 12mm hex key will fit and remove the other end its not a nut but it serves the same purpose
You don't need both to get the spindle out just one or the other
Remember to slacken the pinch bolts on the side you are turning to remove .
It matters not which way you do it the wheel will come out.....................
Theres plenty of the hex keys either in scocket form or just as an allen key on ebay...............scocket is better cos you can torque it up properly with the scocket type when you put the wheel back in
