New clutch not working URGENT
ChowderV4
- My Bike: Zxr400L racer
basically i have the first race of the season this weekend.
Ive installed a new clutch with brand new steels and springs and as new friction plates that are well withing tolerance, all orginal kawasaki.
I've soaked in oil for 24 hours before and made sure they are installed in the correct order, but when i put the cover on the clutch pivot pin thing just doesnt seem to grab the clutch it spins round a lot more than it should meaning even with the cable fully adjusted it doesnt engage the clutch.
Im a t a loss as its all kawasaki equipment and i rang kawasaki asking if the steels were the only and correct thickness and they said yes.
it feels like its packed too thick but the plates are all correct.
ANy help is seriously needed as im losing my mind
my basket does have ome side to side play, could this be the cause or possibly the rivits have gone on the basket?
Re: New clutch not working URGENT
You need to make sure the pin is aligned right to catch the push rod or as you say it will just burl around - have a look and rule that out as a cause.ChowderV4 wrote: but when i put the cover on the clutch pivot pin thing just doesnt seem to grab the clutch it spins round a lot more than it should meaning even with the cable fully adjusted it doesnt engage the clutch.
Oh, if you've put to much pressure onto the clutch cover you may have made a hairline crack in it, pretty sure I have done that before
So once you get it to locate right expect an oil weep once warm , if not you've won a watch
ChowderV4
Yeah I got a crack in my old casing asking from that. Made sure not to over tighten it.
I'll have a look at the pin. But i spent ages fiddling last night and couldn't get it to catch right.
Could the play in the basket have anything to do with it.
Yeah can move the basket left right/up down a but, even the big gear moves, could the basket have been put on wrong/wrong order of washers or something , I've never had it off but I've had clutch slip all last season and tried new plates with no results.
ChowderV4
I had a similar issue before, I ordered the right plates and it wouldn't engage, I ordered from wemoto and they sent thinner plates and it worked but has slip.
Standard are 2.9 or something, I think I got sent 2.7 before and that worked, is it possible someone has put a H basket in for some reason and how would I check
ChowderV4
just tried another basket with all new plates and still wont engage the pull rod
seems to be too much play back and forth in the pin before the rod grabs it
ChowderV4
ok . i am at a complete loss
new steels
new springs
new cable
frictions well within tolerance
all plates soaked in oil and put together in the correct order, friction steel friction etc 6 friction , 5 steels, last friction in the offset tang
tried 2 different baskets and clutch covers
all put together in the correct order
both situations the puller has too much movement back and forth before the pushrod grabs it and wont engage the clutch
HELP ANYONE?
i have a race on the weekend
the only time it has been put together and worked is when i had pattern steels ordered off wemoto that were thinner than the standard kawasaki size.
standard steels 2.92/2.95 or something like that
pattern ones from wemoto 2.72/75 around that mark
when i put the pattern ones together properly the clutch will work fine but i have suffered extreme slip throughout the season and now they are blued and probably warped.
can anyone explain this. Ive rang kawasaki and they said the only correct steels are the ones i got sent.
new steels
new springs
new cable
HELP ANYONE?
Have you got all the washers back in place ?
ChowderV4
all together as it should be
went to the track and tried it with one 2.90 and four 2.70 steels + frictions and springs. works perfect, went to brands and got two 1st places and a 2nd.
- CaNsA
- My Bike: ZX6R F1
ChowderV4 wrote:all together as it should be
shaggy69
- My Bike: ZXR 400 Racebike
ZXRs have two different thickness of steels depending on what clutch is fitted. I have had this issue several times when swapping complete clutches from bike to bike. I have no idea whether the difference is from H to L or KBTL to non- KBTL, all I know is that I have two different types of clutches with different covers that have different thickness steels.
