changing clutch plates- how does it cause cam chain rattle?
ross46
- Restricted
- My Bike: zxr 400 l6
Re: changing clutch plates- how does it cause cam chain ratt
The bike doesn't creep forward in 1st gear and the cable that's on there is all adjusted correctly, I went and spoke to my local bike garage and the mechanic there said that its quite common that you get clutch slip with everything In tolerance, he said its more likely the friction material has started to go a bit, also he said the bluing could be were the clutch has slipped, either way looks like it's new plates, steels and springs, anyone tried the ebc srk kit?
