how can you tell if you have 1 or not?
is there a set of special engine numbers ?
cheers as i would like to know any difining differences
if its in the wrong section then i apologise and please remove
again thanks John
sp engines
SINGATINI
- My Bike: zxr 400
tk400
- My Bike: ZXR400 , ZXR950
Re: sp engines
If it is an L model SP it will have a mitsubishi CDI therefore the crank trigger will be three lobes instead of 4 ( 1 small lobe and two large). It will have a close ratio box, and as it tells you the standard tooth counts in the manual you could check that. It will have SP cams which have adjustable sprockets instead of fixed. L models ( or M actually) had Flatslide carbs as well. those are the most obvious ones. cheers.
Regards TK400
Regards TK400
