1) On idle there is a constant ticking noise, now I dont know if this is normal, but Ive tried the 'pull the clutch in' test and the noise carries on so I dont think its the basket, as you are going along I believe it gets faster, so could possibly be tensioner? (as far as I know cam chains should outlast the engines, they only need their fixings replacing every so often? Where do I buy these bits from, and can you tell me exactly what I need, there is a blade and springs iirc?)
2) At 4100-4300rpm in every gear there is a crackly/crunchy noise, if I pull the clutch in it goes away, either side of this rev range you never hear this noise, all the way up to 12.5k
3) My 1st -> 2nd -> 3rd -> 2nd -> 1st gear changes aint half crunchy, is this because of the age of the bike (1990) or do I need to sort something out?
4) I think I may have a tiny air leak? Ive read the high idling topic, whereby when slowing down to a stop the revs will hold at 2k then drop of their own accord to 1350ish, but Ive found if I brake down to below 2k with the clutch out then pull it in just as it gets to the biting point this solves the issue?
And a more generic question, what RPMs do you guys cruise at through town? I tend to stick to 3.5/4k in the 30/40mph limits, but I thought I read somewhere its best to keep engines in the mid range as they are actually doing less work there than trying to accelerate at lower RPMs? Not sure if there is any truth whatsoever in that!
Sorry for the essay!
