My L model rebuilt basket case had the coils (and inner fairing panel brackets) held on by goodwill and high hope.
Anyone know a botch up, spare part repository, tip, trick, any of the above to mount the coils and inner fairing securely? the original part (the one that was left) is a rubber shroud with a circular female thread held in it.
Any tips or know where I can get something similar?
M?
Coil mounting rubber thingies - botch up?
- markzxr400l3
- My Bike: ZXR400H2 GSXR750
Re: Coil mounting rubber thingies - botch up?
yes, goto a local bike shop preferably a kwak dealer, they are called 'well nuts' or 'top hats' and are less than a quid to buy if memory serves me correctly. Pretty common part across kwaks, more so that where i bought mine didnt even keep em in a stock room but in a little pot behind the counter instead.
Oh, and im sure they are less than a quid each to buy.
- deviant
- My Bike: ZXR400 L3
I presume they get pushed into the frame spars on a pretty regular basis. Keep a bike long enough and you'd prob have loads rattling round in there.
very true, both my ZXR's have the well nut that holds the tank cover on, in the frame now
and mine lolRedexRobB wrote:very true, both my ZXR's have the well nut that holds the tank cover on, in the frame now
- My Bike: ZXR400 L9
- markzxr400l3
Thanks guys, on order.
- My Bike: zxr 400
I had this issue also, thanks for letting me know what they're called!
I know the post is old but I thought of a good botch up! Get a chunk of blue-tac, put a hole into it, then put a metal nut into the hole to act as the thread and squish it into the frame
