running problem
pieface_ie
running problem
Post by pieface_ie »
my ZXR400 racer has been actin up recently i was out on it tonight and noticed that it dosent sound normal, there are flat spots in low revs but once the revs build up she takes off,i also noticed light hazey smoke coming from the oil breather which i dont think is normal is it?and there was also a few drops of a lightish greeny substance dripping from it.
I have checked for dirty petrol,checked that the carbs are properly on and sealed and also checked that the air box is secure and tight.
Any one have any ideas?
The bike was grand recently but all of a sudden just started acting the mickey finn,would electrics have anything to do with it?
Not sure what the smoke is all about from the oil breather, but the green fluid sounds like coolant. Whats the bike been running like temperature wise? Normally the only time green fluid pisses out (in my experience) is when its overheating!
Guest
Post by Guest »
the bike temprature is grand,its no where near the top.any other ideas about fixing it?or was around it?
Someone else also mentioned coolant so im sure your right,
cheers mate
isn't smoke coming out of your breather a sign of piston rings going?
I'm pretty sure that smoke isn't a good thing. :|
Like Baz says, could be piston rings - my guess would be head gasket.
Usually on ZXR's it seems to blow the other way, so that it heats up and all the coolant pishes out, but there's no other signs of a blown gasket, i.e. loss of compression and water contaminating the oil.
If it's blowing coolant into the oil i guess it's more likely to result in power loss and the other classic head-gasket symptons?
Especially if it's blowing coolant aswell, but not overheating.
Your thermostat could also be knackered, so you just don't KNOW that it's overheating. I should think the oil would have to get pretty hot to be steaming through the breather?
All that's worst case scenario though - hopefully it's something as simple as your thermostat's dead and your carbs need balancing! :D
