Cam Chain Guide Needs Replacement
spaz
My Bike: ZXR400L2 with K-RASH
Post by spaz »
Right, mine is broken (when I was installing the cam chain 4 monthes ago it fell out and I didn't think anything of it. I've only just realised that it needs repacement now). Do I need to separate the cylinder head or can I just take the top end off and swap them as simple as bolt on/off?
cheers
spaz
edit
Post by spaz »
sorry, it's the front one that fell out; the one that does not flex from the tensioner
cheers
carsounds_dan
Re: Cam Chain Guide Needs Replacement
Post by carsounds_dan »
Nah they feed in from the front top of the block, have to take rocker cover off, cams out and then leaver it out, use of a right angled pick would be handy,
cheers
dan
...i know, it's great :D
spaz
Post by spaz »
carsounds_dan wrote:Nah they feed in from the front top of the block, have to take rocker cover off, cams out and then leaver it out, use of a right angled pick would be handy,
cheers
dan
Legendary,
thanks mate; I'll do it when I check the shims.
