replacing shims
- zxrtbone
replacing shims
anybody changed the shims??? i need to do it myself so any help or advice would be most gratefull,cheers dudes.
Jackson
No got any extra advice really from whats been said on teh other thread, but when you buy new ones they are about 5.50 + vat from kawasaki dealers, quite pricey if you need a few,
hoever there is a guy on ebay that sells them for 2 quid each posted, -thats where i got mine from. its the 7.48mm diameter ones you will need.
Have fun!
Have fun!
- diesel
- My Bike: Zx7r
- diesel
- My Bike: Zx7r
- deviant
- My Bike: ZXR400 L3
yep, anywhere between none and sixteen.
- diesel
- My Bike: Zx7r
Jackson
hi,
think it was 5 or 6 i had to change. Wasnt difficult at all for me, thats because when i actually changed them for the new ones i had the cams off.
Its pretty easy to check the gaps, just follow the manual and note the gaps of each valve as you check them. Then when you've done them all compare them to what the recommended gap should be - if yours are too big get a thicker shim and too tight a smaller one. But you will need a vernier to measure the thickness of the ones already in if they do need changing. If you aint got a vernier you can get them dirt cheap, i bought a cheap digital blackspur one, brand new for 4 quid and was quite surprised by its accuracy
I imagine swapping them over with the cams on could be quite fiddly, especially on the intake side due to the angle of the engine in the frame. Either way definately get one of them magnets to draw em out - they are only held in by oil suction.
oh, and the seller id was morris2006 on ebay, just mailed him the sizes and sent paypal, got em the next day. Although it looks as his price has gone up a little, still cheaper than dealer though
- BigNinjaDave
- My Bike: ZXR636, ZXR400
Granted it is for a ZX6R so the engine layout is a bit different but in conjunction with the 400 workshop manual it should tell you everything you need to know:
http://www.themcdonalds.net/richard/bik ... lves.shtml
Ive never done it, so wouldnt know what to write, it is something id like to get round to doing tho purely so i can do the work myself and get a write up. Ive still got loads of other stuff to do for the workshop section which ive never got round to yet, only managed whats there at the moment in two years!Black Box wrote:Baz and Rob how about a writeup under the workshop section about this for us non ZXR specialists.
I've never done shims with the engine still in frame but certainly you can change them with the camshafts in place..........fiddly but yes it can be done.
I found for getting the little buggers back in a lightly magntised scribe or small jeweliers screw driver was best along with a non magnatised one to help remove the shim from the magnitic one and manouver it into place
