head gasket gone on mi 400l
- My Bike: zxr 400 l
Any body know where i can get a manual head gasket gone on my baby i know what i doin just need tecnical data ie sequence of bolts to torque first on head and also what nm settings cheers fellow zxr ers
- Miles
- My Bike: ZXR 400 L3
Re: head gasket gone on mi 400l
zxrworld.co.uk
Has the L H & racing manual all there as well as loads of other information
Cheers miles but getting hold ov em like rockin horse poo
- Miles
Just go to the website and download them as pdf files or look on eBay they come up often enough.
- Dominik
- My Bike: Zxr 400 L3
The order to tighten the bolts is engraved in the cylinder head. Torque is 25nm I think. Losen the bolts in the opposite order starting with the outer ones. Be careful with the cam covers and lose the bolts step per step over cross.
However the linked manual has more detailed information so just give it a look...
Zxr 400 SL - 130kg
Thanks dominik i know how to do it am very apt just needed torque settings but cheers for info
- fstarocka
Yes 18ft lbs / 25nm. You undo in a criss cross spiral towards center and install from center outwards in two or 3 steps.. Don't forget the 6mm bolt inside timing hole.. And the oring seal in head at front right cam chain cover (2 hex bolts), it's the primary oil feed to the cams..
Sent from my SM-G900M using Tapatalk
