Are H pistons the same as L???
- My Bike: zxr400......suprisingly
I believe the rings have the same part numbers.......but what about the pistons? Anyone?
- Miles
- My Bike: ZXR 400 L3
Re: Are H pistons the same as L???
A standard L piston part number is 130011333
So check that against the H
As for base gasket a lot of racers run without it as it slightly increases compression. Don't know if you need to use a liquid gasket in its place though
