ross46 wrote:I'm a bit sad sometimes, so for the last 4 hours ive been trying to work out your high cylinder compression, so far my only ideas are;
Valves too tight
Did you clean the carbon of the pistons and head?
Compression tester faulty
its odd, because reading the OP's previous posts he used the compression tester not so long ago, and he hasnt mentioned messing about with the valves. im doubtfull that he could do that many miles on the bike that it would foul with carbon so much that his two readings before/after the gasket, could be so out.
the HG on the zxr (im still to remove mine) is it a single gasket, or is it like my fzr 1000 where its 3 gaskets stacked on top of each other?
there is a chance that someone was running with 2 stacked gaskets, and you have removed these and just replaced it with a single gasket?
also did you do both readings (before and after HG swap) with a warm engine, or is this a cold reading (i suppose if you cant start it it must be...).
even if the pulsar plate had shifted it wouldnt affect your compression, just your spark timing.
is it possible (ask moriman) that your bike has the SP's high-comp pistons? in which case 180psi is about right and you will need to run ~98RON fuel, so thats uk premium fuel, it will knock with 95RON most likely.
