Worn Cams From Knee Down
mikeee
My Bike: ZXR400 L9 (1999)
Post by mikeee »
Hi
Soo according to the garage i take my bike to have have worn cams on the left hand side (piston 1/2), the guy says that this is most likely occured from that side being starved of oil, so i asked him if getting my knee down a lot on the right hand side could cause this, and he said it's most likely, yes. just thought i'd share this, as its a new one to me, maybe its not true, i dunno. :)
Mike
Bridgestone BT-023's
Renegade Exhaust
Carbon Fibre Fork Preload Adjusters
Wezmoto Braided Hoses
Black Short Levers
Black Double Bubble
CaNsA
My Bike: ZX6R F1
Re: Worn Cams From Knee Down
Post by CaNsA »
Could be a blocked oil feed...... geek
mikeee
Post by mikeee »
possibly, well its booked in wednesday, as replacing cams is past my limited expertise. hopefully they'll sort it out and check the oil lines, having the carbs balanced aswell :)
Renegade Exhaust
Black Short Levers
Black Double Bubble
bendog66
Post by bendog66 »
could also be not warming it up enough
mikeee
Post by mikeee »
again, possibly, although i do try to warm my bike up before i set off and keep the revs low for a bit, but then if it was due to not warming it up, would it not be that all the cams were worn not just piston 1/2??
:P
Renegade Exhaust
Black Short Levers
Black Double Bubble
bendog66
Post by bendog66 »
oil flow goes from right to left so you're more likely to get it where you've got it
mikeee
Post by mikeee »
hmmmm, makes sense. just changed the oil and filter, and there was a lot, and i mean a lot of metal bits in it :S
Renegade Exhaust
Black Short Levers
Black Double Bubble
CaNsA
My Bike: ZX6R F1
Post by CaNsA »
mikeee wrote:well its booked in wednesday
Oh snap girlfriend!
So is mine :D
bendog66 wrote:oil flow goes from right to left so you're more likely to get it where you've got it
Good post I think now take your thoughts to a logical conclusion
mikeee
Post by mikeee »
Oh snap girlfriend!
So is mine :D
What's up with yours then CaNsA?
Renegade Exhaust
Black Short Levers
Black Double Bubble
Tirpitz
My Bike: Kawasaki ZXR400L4
Post by Tirpitz »
mikeee wrote:Hi
Mike
I'd be finding another garage. So he reckons that a motorcycle engine, which is designed to function properly at various inclinations to the horizontal whilst cornering (no rider on earth ever went round a corner with a bike bolt upright!), has chewed its cams because it has been run whilst inclined at a normal angle.
The bloke's either a complete tosser or a rip-off merchant.
Hel braided hoses
Pirelli Diablos
Ohlins steering damper
A16 carbon fibre exhaust can
Nitron Sport shock
mikeee
Post by mikeee »
i only mentioned this as, on a wednesday night we go down to a local roundabout which has a nice surface and isn't busy at all, be it a roundabout, i only go down on the right hand side and have been doing so for a few months, it was just a suggestion, probability is my oil pump is on its way out or so. :)
Renegade Exhaust
Black Short Levers
Black Double Bubble
