valve clearance figures plus how to remove shims
				TheG
 - My Bike: currently cbr125
hi i have been following the valve clearance and shim swap thread which has been very good so far
this is my first valve clearance service
the reason why i have posted this is due to my figures i have got whilst checking the clearances with a feeler gauge
so here goes
cylinder 1
ex valve left 0.12mm right 0.11mm
inlet valve left 0.13mm right 0.11mm
cylinder 2
ex valve left 0.11mm right 0.17mm
cylinder 3
ex valve left 0.13mm right 0.15mm
inlet valve left 0.14mm right 0.14mm
cylinder 4
ex valve left 0.11mm right 0.16mm
inlet valve left 0.11mm right 0.11mm
ex valve tolerance 0.16mm - 0.21mm
inlet valve tolerance 0.12mm- 0.17mm
so my valves are very tight which im worried about, the other problem im now having is i cant get the shims out so any advice on how to get them out would be appreciated thanks
so here goes
cylinder 1
cylinder 2
cylinder 3
cylinder 4
				guitarcarrot
 - My Bike: ZXR 400 L2
Re: valve clearence figures puls how to remove shims
Short answer:- inspection recovery magnet with a 4 inch flat head nail attached to it.
Long answer:- (couldn't sleep)
Hi mate, bloody hell! Good thing you opened her up! Some of those zorst clearances are making me cringe, if the clearnaces get too small, the valve spends longer open, and therefore doesn't have the oppotunity to pass as much heat onto the cyclinder head to be dissipated, so you're right to be worried in my eyes, but at least you've caught it before its too late
in extreme cases the valve will never shut, and will result in burnt valves, which will be expensive,I'm doing my vavles at the moment too, most of mine where on the lower edge of the boundary so I'm being cautious and moving them up towards the larger gap boundary lol,
As for getting the shims out, the rocker arms are spring loaded so you can slide them along the shaft and nudge them up or down to secure them out of the way. Now you can see the shim in the centre of the spring, the way I got mine out was using a magnet, however the inspection/recovery magnet I had was too strong and kept sticking to everything but the shims, so I took a 4 inch flat head nail and attached the flat head to the magnet and used to pointy end of the nail to poke the shim and they will lift out usually on the first or second poke because the magnet has temporarily magnetised the nail (Y) having said that, the inlet shims closest to the frame were too awkward to use the delicate nail, so I resorted struggling with the original magnet alone,
Anyhow good luck!
Anthony
Anyhow good luck!
Anthony
				beermaker
 - My Bike: Kawasaki ZXR400H2
Good thread - will be checking my valves and the like when I start rebuilding the bike.  Great tip about the nail, will definately bear that one in mind!
Out of interest did u let the bike cool for 24 hours before measuring? If not that will give inacurate measurements.
				guitarcarrot
Yurrpp I did indeedy
				TheG
yes the bike wasent used for 2 days before i checked them
				TheG
Bit of a update i did manage to get the shims out but measuring them proved difficult with a imperial micrometer getting allsorts of odd readings, got a different reading checking the same shim a few times so thought it was no good.
I have been away since now im back i want to finish it so i can get out on my bike, i have ordered a metric digital guage but after buying it i have read the accurecy is within 0.02mm.
I spoke to someone earlier who said valves normally become loose and its odd mine are tight, i am sure iv read tight valves are normal over time and use of the bike ?
Before doing this work the engine clicked from cold and went whilst warm but starting it once it was warm was a pain.
I have checked my clearences more than once on different days and there was no way i could get a feeler gauge within spec in the gap so they must be tight.
Starting to feel a little nervous about this now as people are saying i am brave to be doing this and that its a "very difficult job"
I would be gratefull if someone could post back about the micrometer and that evreything im doing sounds right, at the moment i have put all the shims back in as the results i got with the imperial guage and once converted were no use at all.
Once again much appreciated cheers.
I have digital vernier calipers and they are fine to use. When i did mine i did exactly as you did and measured everything twice. I assume you are taking measurements at the correct part of the engine cycle by turning the crank till the lines mark up on the pick up? Otherwise someone could have just done thier measurement wrong in the past and everything is tight.
				TheG
- Tirpitz
 - My Bike: Kawasaki ZXR400L4
Re: valve clearance figures plus how to remove shims
Don't worry that you're measuring tight valves, they do tighten up.  Whether clearances tighten or loosen as a result of wear depends how the valves are actually actuated in a particular engine, so anyone making a blanket statement that 'they loosen' is talking shite.
This is not 'a very difficult job', it is maintenance. It is fiddly and time consuming but it is within a competent home mechanic's skills if they take time and care.
My valves were tight at 11k - none of them were loose. I made the whole lot looser as required and the engine now runs beautifully and with much less valve train noise. Some of my valves were a hell of a lot tighter than yours and they were done at 6k. Take your time and trust yourself, you'll get there
Hel braided hoses
Pirelli Diablos
Ohlins steering damper
A16 carbon fibre exhaust can
Nitron Sport shock
						Hel braided hoses
Pirelli Diablos
Nitron Sport shock
				TheG
ok thanks
 i too and hoping for a smoother easier starting engine
just waiting for the vernier caliper to arrive hopefully later this afternoon
				TheG
measuring tool arrived and have got all the shims measured as accuretly as possible, i also measured the shims before with a imperial micrometer and results are the same or very very close
once again my valve clearences are below
i have changed the odd clearence and i have measured them all again so in total twice now
cylinder 1
inlet valve left 0.14mm right 0.11mm
cylinder 2
cylinder 3
cylinder 4
my shims sizes that came out the bike today are
cylinder 1
ex valve left 3.09mm right 3.08mm
inlet valve left 3.00mm right 3.04mm
cylinder 2
ex valve left 3.08mm right 3.04mm
inlet valve left 3.04mm right 3.04mm
cylinder 3
ex valve left 3.09mm right 3.10mm
inlet valve left 3.05mm right 3.05mm
clyinder 4
ex valve left 3.05mm right 3.00mm
inlet valve left 3.04mm right 3.05mm
what i want to know is how do i get the correct shim sizes, iv done some working out from a formula of google but im left with odd shim sizes like 3.02 and i cant buy that size shim
if anyone could get back to me about this it would be great thanks
cylinder 1
cylinder 2
cylinder 3
cylinder 4
cylinder 1
cylinder 2
cylinder 3
clyinder 4
				thomp1983
 - My Bike: zxr 400 l3
if your sure the 3.02 is the right size just round it up to the next 0.05 you can get probably 3.05 the tolerance on valve shims are big enough for that the inlet clearance is 0.12mm to 0.17mm and exhaust 0.16mm to 0.21mm thats a 0.05mm range so going up 0.03mm (3.02 to 3.05) will still leave you in spec
chris
						chris
				TheG
Hi done all the maths going to order new shims in the morning hopefully my measuring is accurate
i have measured evreything twice from taking the clearences to measuring the shims
so fingers crossed evreythings ok when the new shims go in and i check the clearence and hopefully i can put it back together and start it
cant belive iv missed all this good weather
- Tirpitz
All of your shims should be sized in 0.05mm increments (i.e. dividing by 0.05 gives you a whole number).  If you are absolutely sure that you have measured the ones that aren't correctly, that means the shims themselves have either worn or are poor quality.  However, given that the tool you bought is only accurate to 0.02mm you need to factor that error in.  TBH I would be surprised if 9 of your shims were crap / worn as they appear to be from your measurements, I suspect it is an accuracy issue with the tool.  For any of the measurements which are not in a 0.05 increment I would round them up or down to the nearest 0.05.  This will make working out required shims easier.
These modern electronic tools eh? I've got an old manual vernier caliper and it's more accurate than that. £10 off Ebay! Progress?
When you put the new shims in, whatever you do make sure you have blocked up the oilways in the head and the camchain tunnel with rags. You WILL, GUARANTEED, drop a shim and it WILL go into the engine if it can.
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
						Hel braided hoses
Pirelli Diablos
Nitron Sport shock
