can someone tell me if there is some magical way of fitting the clutch casing
my lads h model casing was leaking from a crack around one of the bottom bolts at the rear of the casing
he got a replacement off ebay that looked ok so i fitted it today and guess what cracked and leaking from the same bolt and from one at the top as well
is there some kind of black magic voodo to fitting them or is this just bad luck and no i didnt over tighten (9.5 nm) used sealer and nipped up opposite bolts same as with torque wrench
im relly p*ssed off with it
ive put a wanted add on the forum if any one has one pm me please
