has anyone tried the profile from Kent Cams for the zxr?
if not, what cams would people recommend? oh, and at some point i'm planning a 444cc overbore.
(and what does "FFS" mean on the smilies panel on the right?!)
Gav
Edit: Speaking of which, anyone tried the +3mm overbore to get 444cc? I've seen the kit on tts performance, bout £600. Thoughts?
kent cams?
- gavinfdavies
kent cams?
Re: kent cams?
means............... for **** sake
the little stars replace a four letter word begining in f and ending in k that looks a little like a certain designer label
I believe it's an expression of frustration for whatever reason
never used Kent cams......................and 3mm oversize is not legal for racing so I've not ever considered it
Re: kent cams?
i've not used kent cams as oversized shims are needed .. and um .. where do you get them ?
Re: kent cams?
Kent ?zimm wrote:i've not used kent cams as oversized shims are needed .. and um .. where do you get them ?
Re: kent cams?
cargo wrote:Kent ?zimm wrote:i've not used kent cams as oversized shims are needed .. and um .. where do you get them ?
funny..
but no..
afaik you have to get the bloody things made each time...
Re: kent cams?
prob better off with a good set of reprofiled SP cam ?
- gavinfdavies
Re: kent cams?
i've seen these SP cams mentioned alot, i assume SP isn't a brand, it refers to pinching the cams of an SP version on the zxr?
Re: kent cams?
yep
