annoying noise
hieroglypkic
- My Bike: zxr 400 L
annoying noise
hi everyone recently ive been getting a weird tapping type noise from my engine the higher i rev the more it taps the closest thing i can think of which sounds like it is when you put a card in between the spokes of a bicycle wheel
- jake
Re: annoying noise
do you have a card stuck in your wheel?
check that first
then have a look at your camchain and tensioner
check that first
hieroglypkic
Re: annoying noise
hahhaahaha well ive looked and theres no card so tomorrow ill be taking the beast apart =)
- extonyg
- My Bike: zxr 400 L1 uk
Re: annoying noise
possibly valve clearances as well.......
bob_mojo
- My Bike: Zxr400
Re: annoying noise
Hi
My boss test drove my ZXR and said it has the same problem (my test is tomorrow)
if You sort this out could you explain how you did it.
Please say i dont have to take the engine out!!!
Re: annoying noise
most likely valve clearances. Engine doesnt need to come out but its supposed to be alot lot easier. Theres a guide writtem by Mori Man on how to do the clearances. Its at least a half days work if you havent done it before.
Re: annoying noise
im going to guess its a worn out cam follower (tappet).. loose valve clearances arent normally audible at high revs no matter how slack they are.
if its on the intake side i think its engine out to do it.. exhaust side is tight, but doable in the frame from memory.
bob_mojo
- My Bike: Zxr400
Re: annoying noise
i just had a job intetview at a bike tuning specialist.
i am going to take it to him ( cheating i know) so he can have a look and proffesionally diagnose and potentially fix the problem.
but thanks alot everyone
