Hey,
I've rebuilt my engine but its been left standing for a while, is there anyway to turn the engine over manually with all the oil/fluids in without having to take the RHS cover off?
Also as it has been standing for a while should I give the engine a spray with a bit of WD40 or just put the oil in and hope for the best???
Ciaran #65
Turning engine over manually
- U_h0rnet5
- My Bike: ZXR400
- extonyg
- My Bike: zxr 400 L1 uk
Re: Turning engine over manually
i dont no if its possible but you might be able to put it in gear on a paddock stand and turn the wheel as that should turn it over (i could be wrong though never tried) but overwise just lean it over slightly to the left and take the right hand casing off and you wont loose any oil.
how long has it been stood for?my rode bike got put away for about 2 months and i started it up no problems.
- U_h0rnet5
- My Bike: ZXR400
Well I got the engine in May 2008, stripped it down as the head gasket had gone ever since then its been sitting in my my spare bike while I got all the other things sorted.
If it's in the frame with all electrics and a battery just turn it over with the starter motor.....................if you want to do it with no spark plugs in it will spin faster and clearly not start. If taking the plugs out is too much work then turn it over with the ignition pick up unplugged and it will turn over without starting
Sitting on the bench it's no big job to take the ignition pick up cover off and turn it over with a 19mm socket...............clockwise. Do it with plugs out it will be easier
Tip it to one side and no oil will come out......................
- U_h0rnet5
- My Bike: ZXR400
Yeah its all in the frame most of the electrics are connected one thing I want to try out really as well!
If I take the plugs out, would it be a bit beneficial to spray a little WD40 in the holes?
- CBT slow
- My Bike: zxr400 H2
i wouldnt to be honest, you could stick a couple of drops of petrol down there with 2 stroke oil in it just to help it ,till the oil gets back round once started, but like i say a little bit, you dont want to flood the engine
but saying that i think most people wouldnt bother
To my mind the only reason to turn it over manually is so that the oil pump is primed and pumping oil..................if you can turn it over without it starting using the starter motor it will raise enough oil pressure to put the oil light out....................you can do no more than that really.
When it comes to actually starting it fresh fuel in the tank/carbs is good and a pre warmed set of plugs is good too in my experience I warm them with a hot air gun hot enough to lift your skin off your fingers.................get the hot plugs in the bike and hit the starter with full choke.....................should fire up OK.
Once on a really cold day I filled the radiator/cooling system with very hot water from a boiled kettle. Don't know if it helped but sure as hell confused the temp gauge LOL
