valve clearance figures plus how to remove shims
				Rasta-ninja
 - My Bike: zxr 400
Re: valve clearance figures plus how to remove shims
I second that!!! getting shims out is nowhere near as fiddly as putting them back in, so just take your time and make sure you've properly covered the hole beneath the cam chain. I didn't and i dropped one down there but luckily it popped out at the cam cover. Oh and make sure you lube everything back up with a bit of oil
				richr
 - My Bike: zxr 400
Hope this helps
i used a thick piece of welding wire (mig or tig type) flattend the end and bent it over slightly, put a magnet on the wire and a tiny amount of grease
you will find it easy to place the shim in and the "grip" of the magnet iasnt enough to pull the shim back out
Jobs a good un
Jobs a good un
