Part ID
Dannyk
- My Bike: zxr 400 L3
Part ID
Can anyone help me id this spare part i have? Recently replaced head gasket, this came from somewhere on cam chain side. Got a part number of 32160-1134. Any ideas where this goes? i looked at exploded to no avail. Also seem to have a quiet a bit of oil coming down to cam tensioner, is this normal?
Dannyk
Re: Part ID
make that 92160, found it on the microfice, althoug not sure where it goes
Re: Part ID
its the battery of your mobile
Dannyk
Re: Part ID
i think it looks rather like that too, but tht dont help i afraid
Re: Part ID
sorry mate, i've looked at the microfiche and trying to rack my brains where it goes, i'll look throught the manuals.
Dannyk
Re: Part ID
I cant figure it for the life of me, not shown in the manuals. All i can say is that when i removed the cam chain cover and the timing wheel, it popped out from that gap, ie fallen down i can only guess. Bike is back together and running well - bit sluglish, i assume due to carb balance, but all seems well
mpotnoodle
Re: Part ID
it goes in recess behind the timing rotor cover,at about 11 o`clock on a clockface it just pushes in at the back of the chain guide and sticks out a little bit you will notice a recess on the timing cover that the end sits in,probably best to fit it back in before you do any possible damage to the engine
mike
mike
Dannyk
Re: Part ID
Yeah i want it back in. there for a reason and all
So is it behind the tensioner?
Thanks in advance
Thanks in advance
mpotnoodle
Re: Part ID
just looked in the manual it says it is a damper rubber for the rear camchain guide,well thats what it looks like no mention of number in manual though,have a look in top left corner inside the cover and see if it is there
mike
mike
Dannyk
Re: Part ID
What would you class as a normal amount of oil at this side of the engine
mpotnoodle
Re: Part ID
i don`t know how much is supposed to go down there but with the oilgoing through the cam caps etc and splashing around with the cams there will al ways be oil going down to lubricate the camchain and other parts on its way down the engine again as this is one of the ways it will do this,hope this helps
mike
mike
Re: Part ID
i wouldnt worry too much about the damper ... i did 30,000 miles without one once as i couldnt work out where it went either .. didnt do any harm to the engine, and popped it back in a few months later when i'd figured out where it belonged.
