Was riding and noticed steam/water(coolant) spraying out of the top left of the radiator. And idea what my next step should be? Haven't had the opportunity to look her over as she is stuck at work. Reluctant to ride home in fear of damaging something.
Thanks.
(1994 L model)
Sent from my E6653 using Tapatalk
Radiator leak
- Miles
- My Bike: ZXR 400 L3
Re: Radiator leak
Definitely a hole in the radiator? Could be a split on the lhs hose.
Re: Radiator leak
Top left when your sat on the bike is probably a leak, top right of you were facing the front of the bike could be from the radiator cap.
You need to wait till your bike cools down, top-up.the expansion bottle and the radiator and run your bike back up to temperature with your side panels removed. This will give you a clear indication of where the leak is coming from.
If you're close to me I'll come down and check it out for you
- My Bike: zxr400 1996
Re: Radiator leak
It was definitely top left when sitting on the bike.banner001 wrote:Top left when your sat on the bike is probably a leak, top right of you were facing the front of the bike could be from the radiator cap.
Where abouts are you. I'm based in Bromley (south London).
Matt
Re: Radiator leak
Probably a rad leak then, possible to get them plugged, if it's bad or all the aluminium is really corroded then it's new rad time, if it's the body of the rad you might be able to get it filled or welded by a damn good welder.
I'm in nuneaton in the Midlands, I can come to you but would need petrol covering and that's about £35, so use me as a last resort.
