High temperature, fan not helping?
Madderz
- My Bike: 1992 Kawasaki ZXR400
Hello again beautiful people.
What a beautiful Saturday morning! My battery arrived and first thing I whacked her on and went for an amazing ride. Sat at some lights I notice my gauge 3/4 the way up, so i lean the bike look down to the left, the fan is sat still?? Hmm. So I pull up short the fan cool her down. Wiggled the fan switch plugs, felt the rad (hot) everything seems fine. There's coolant in the expansion bottle. So anyway head home, on the way back I'm sat still and i hear the fan kick. Brilliant! Look at the gauge and it's almost in the last red bit! So I sit and wait, urging the fan on but it wasn't getting any cooler! So off I get, short the fan cool it down to halfway and got her home.
That was 2 minutes ago.
So, fan is kicking in, although in my opinion it seems far too late. When the fan is running it's not cooling the bike.
Now to me, this shouts 3 possible things that it could be/be a combination of:
1: Dodgy fan switch (OMFG £76 from Cradley)
2: Low/no coolant
3: Air lock.
Any ideas people? When she has cooled down I'm gonna pop rad cap off double check the coolant and run her up to temp with it off to get any air locks out.
Wanna get back out on her today!
2: Low/no coolant
3: Air lock.
He who dares, Wins.
- CaNsA
- My Bike: ZX6R F1
Re: High temperature, fan not helping?
Check coolant
Might need a new rad sensor on the back of the rad, left side, middle.
Madderz
Hey,
Quick update, I took the rad cap of, topped her up and ran it till the bubbles stopped (except the bubbles from coolant travelling into the rad from the top hose).
Took her for a spin. It was bett but the temperature was still raising above a comfortable level.
The fan seems to kick in when it likes, sometimes when temp is half way an other time it comes on then goes off.before the temp has even gone down!!
I assume the fan switch (the big nut shaped thing with the two wires you short sticking in the left hand side of the rad as you sit on it) is just the same as a coolant temp sensor and makes the circuit when at a certain temp.
Does this also control the temp gauge? If so is there a possibility if the sensor is dodgy it would put the incorrect temperature on the gauge?
I just don't get why when it's hot and the fan DOES kick in it doesn't cool the bike down? Usually I'd say air lock, bur I'm pretty sure there isn't one I ran it with the cap of and the nose of the bike higher than the rear on my drive.
Another thing crossed my mind.... I thought my cct needed changing due to a noise under the tank, if it was the water pump bearing making the noise would coolant still get to the rad? Just a thought.
Kinda stuck scratching my head. She is running sweet as a nut. Just high temp :/
Maybe a coolant flush and a longer bleed maybe? What are these bike like for air locks?
He who dares, Wins.
Madderz
Just flicking through other threads, saw you say this cansa:
"**DO NOT DO THIS ON A HOT/WARM ENGINE***
really
***DO NOT DO THIS ON A HOT/WARM ENGINE***
Pull the rad cap off, start the bike and look down the filler hole.
if you see a steady stream of bubbles then the head isnt seated correctly and the gasket isnt sealing."
There was a steady stream of bubbles where you fill the rad :/ I assumed it was just the moving water
Gonna have another go at getting the air out if not then it's head gasket time...
FFS!
really
FFS!
He who dares, Wins.
Madderz
However, I did this on a warm engine? Would that make a difference or is that just a warning for taking rad cap off?
He who dares, Wins.
- CaNsA
- My Bike: ZX6R F1
If its a hot engine you run the risk of steam and coolant melting your face when you take the rad cap off.
Madderz
Ohhhh yeah I see. Disclaimer. Lol.CaNsA wrote:If its a hot engine you run the risk of steam and coolant melting your face when you take the rad cap off.
Right update 2
Emptied coolant.
Refilled
Ran up to temperature with cap off.
I think I have the bubbles you speak of cansa, mind having a quick look at this short video? Let me know what you think?
http://youtu.be/FYe9ChY_DoA
He who dares, Wins.
- CaNsA
- My Bike: ZX6R F1
Yeppers, looks like the coolant system is being pressurised, i had the same problem on my 1st zxr.
The gaskett was seeping between cylinder 2 & 3 and causing exhaust gases to get into the coolant system.
After a decent ride do you hear the coolant overflow bubbling?
Madderz
I can here it doing something in the expansion tank, sounds more like sucking or blowing and trickling water. Never really looked tbh. Im trying not to ride it and warp the head. It's definitely using coolant. I just when and checked and I can't see the water level.CaNsA wrote:Yeppers, looks like the coolant system is being pressurised, i had the same problem on my 1st zxr.
I would have thought with it burning water there'd be white smoke?
He who dares, Wins.
- CaNsA
- My Bike: ZX6R F1
It doesnt burn water, just vaporises it.
It wont be vaporising enough of it for you to see the steam, unless it completely blows the gaskett and shits all over the place.
I know where you are right now, stop living in denial and accept it.
Get it to a grease monkey.
Madderz
Paha! Fair point. Accepted. Head gasket has goneCaNsA wrote:It doesnt burn water, just vaporises it.
Grease monkey? F*** that. I'll do it!
@Cargo
Same difference. You knew what I meant.
Sooo.... Plan is:
Order gaskets (exhaust, and head)
Soak up the exhaust manifold bolts extensively with wd40.
Drop engine out.
Replace gaskets.
So with a car, it's always best to replace the cam belt whilst you're in there. Same thing with the cam chain I take it?
Anything else worth doing while the engine is out? Anything to watch for whilst doing head gasket aside the obvious (correct timing etc)
He who dares, Wins.
- CaNsA
- My Bike: ZX6R F1
Yeppers, use a Genuine Kwak gaskett.
If the cam chain needs it then swap it out.
But check the head isnt warped before you fit the new gaskett otherwise you will be doing it all over again in a weeks time.
Madderz
Yeah, will be using Cradley for all my bits.CaNsA wrote:Yeppers, use a Genuine Kwak gaskett.
Yup engineer straight edge and some feeler gauges on the ready.
Not sure when I'll get round to it as I'm moving house in the next couple of weeks but I'll keep the site updated.
Might even do a write up with some pictures for it.
Is it possible to do it in the frame or is it just easier to whack the lump out?
He who dares, Wins.
- CaNsA
- My Bike: ZX6R F1
Drop the lump, no need to make things difficult for yourself.
Madderz
Huh?
A genuine one's £19 from Cradley.
No point going cheaper than that is there? Or was that your point?
With something like a head gasket no point going cheap. Do it right or do it twice. Lol.
Edit: I have a feeling something just went over my head... Paha.
He who dares, Wins.
