water pump leaking help
- My Bike: 01 zxr 400
helo people water pump started leakin after short run from cover of pump at bottom bolt is tis common and wil a new seal fix ? i tryd puttin engine sealer cus there wasnt any on it for sum reason didnt wrk so new seal shall be tryd next .
- CaNsA
- My Bike: ZX6R F1
Re: water pump leaking help
I'll give you an answer once I finish my Polish night classes
thx for the help :wanker
- CaNsA
- My Bike: ZX6R F1
No need for that.
If you had posted in a way that is easy to read, and not used chav speak, possibly even tried a little punctuation and embraced a spell checker we might be able to understand you.
its not tat complicated now you must be just startin to learn how to read
Fixed for you CaNsA and cargoeg6ray wrote:Hello good people. My water pump has started leaking after a short run, from the cover of the pump at the bottom bolt. Is this a common problem and will a new seal fix it? I tried putting liquid gasket around the pump cover as I thought this may remedy the problem. Alas, this didn't work. So I believe a new seal shall be tried next which shall hopefully have a positive result. Many thanks for any input on this as I would appreciate any help from the experts on this fantastic forum. Humbly yours, eg6ray
Fairplay to you
ZXR 400 water pumps are not rebuildable................there are two seals internally one to keep water in and another to keep oil out.
I cant remember if the water pump cover has a gasket or a rubber seal..............a quick look at the manual will tell you.
This seal is I think replacable however regualr sealler might just do the job
Note there is a small hole on the pump this is a tell tale.......if water or oil is leaking from this hole throw it in the bin and start again
its wasnt the o ring seal atal it seems to be comin from a tiny hole on bottom of pump wat will i do nowcargo wrote:ZXR 400 water pumps are not rebuildable................there are two seals internally one to keep water in and another to keep oil out.
you have failed to read my post that you now quote back at me.
Try again
Try again
O i c so new pump then and you cant refurbish them either tis is guna be pricy im frm ireland
- CaNsA
- My Bike: ZX6R F1
if i was to seal the hole for a little while ... until cud get new replacement wat damage wud it do ?
- CaNsA
- My Bike: ZX6R F1
Seeing as you either don't really know how to spell thinks correctly, or you think posting on this forum is the same as texting your chav mates I can only assume your last post was referring to one of the following.eg6ray wrote: seal
Or
