Leaking Coolant
Leaking Coolant
My bike is leaking coolant from the overflow tube on the expansion tank. It is fine on short trips but anything over 10 or 12 miles it happens. I have flushed out the rad and put fresh coolant in but it still happens, anyone got a clue why this is ?
Re: Leaking Coolant
could be a blockage in the coolant system? any signs of the dreaded head gasket?
Re: Leaking Coolant
No not realy, there is no gunk in the oil and the bike doesn't get too hot
- My Bike: Unique ZXR400
Re: Leaking Coolant
Not above the top line. I have just looked at the rad cap and there is a small split in the large seal, would that cause this prob?
Re: Leaking Coolant
sorry to be the bringer of bad news .. and of course i may be wrong .. but if its blowing water out of the expansion tank on runs longer than 10-15 min and NOT overheating/running hot.. its quite possibly blown the head-gasket and is pressurising the cooling system.
Re: Leaking Coolant
Yep, gave in and put in a garage and it was indeed the head gasket. never mind done now
