Hi Guys,
I recently noticed that when gunning for this one corner, at around 100mph (Donnington Park) - I roll off the throttle slightly.
Upon rolling the throttle back on (1-2 seconds, in same gear and at same speed) the bike is hesitant to rev for half a second, and is then fine?
To make matters even more confusing, I ran out of 'ON' fuel yesterday, so had to switch to 'RESERVE'.
When I came to the same corner, at the same speed, I rolled off, then back on and there was no delay / hesitation at all?
Any ideas as to what it might be?
Don't want to run around on RES all the time, incase I actually run out of fuel! lol
Hesitant when rolling off then on at speed?
- Wabby
- My Bike: ZXR400
- Wabby
- My Bike: ZXR400
Re: Hesitant when rolling off then on at speed?
does it do it with a full tank of fuel?
sounds like it was just short of fuel considering you had to switch to reserve.
A bit careless running out of fuel on a track If that is indeed where you wereso had to switch to 'RESERVE'.
If it runs perfect on reserve and crap at 'on' then it can only be fuel tap or filter.
