Hello, had my carbs vapour blasted and ultrasoniced . Came back looking great, fitted to the bike and fired up first time.
I then noticed that my choke plungers were jammed open. After removing the carbs i wasn't even able to close them by hand. I managed to pull one out, it was heavily scored.
The problem is within the "choke tunnel" not the plungers. Could anyone see any issue with me stuffing some fine wet n dry through the tunnels to try and stop whatever is scratching and jamming them open?
Wet and dry choke
- Miles
- My Bike: ZXR 400 L3
Re: Wet and dry choke
You mean the tunnel that goes into the carb Venturi? If so then i don't see a problem as long as it's just to smooth it out a bit, however you might have debris in the brass pipes that go from the float bowl to the choke...I.e. you won't get any fuel flowing with the choke open...Just more air.
- Miles
Sorry wasn't very clear. I mean we're the actual choke plungers and spring go. I managed to remove them but they were jammed in solid.
I'll sand the plungers and where they slide into on the carb
