This l3/l4 I bought as a none runner is slowly coming together and once the carbs and fork seals have been sorted, I hoping to get her mot'd
Bike was initially a none starter so commenced by doing a good "banner" strip,clean and examination with the carbs internally pretty clean to start with so assembled it & got it to run..... but badly.The pilot screws were adjusted to 2 turns out.
Replaced the o rings at the float valve's as it was overflowing and did my best to balance the carbs whilst trying to keep the motor running (hanging revs & would not idle by itself).Squirted carb cleaner at the carb holders and revs rose a lot so ordered new ones from Cradleys.
With much excitement,after smearing some engine oil on the clamp side of the holders to help get them on, I fitted the new holders this morning but that did not seem to help anything so then adjusted the pilot screws to 2.5 turns out which seemed to make a positive difference in that the bike revved nice & sharply but still the revs hung a lot but now not always. Still could not get the thing to idle.This was after trying to get the carbs rebalanced the best I could. This was all with the choke closed.
Something told me to squirt some more carb cleaner at the new holders at lo & behold, the revs went up again indicating it still had an air leak
I am determined to get this sorted!!!!! Would some rtv sealant help do you think around the new holders?
