Hi folks just wondering if it's possible to swap carbs from a '02 for a set from a '98 model. I know they're both L models so I can't see any reason why not but it's always good to double check with guys like yourselves.
alex
Changing carbs
- My Bike: zxr400 l9
- Miles
- My Bike: ZXR 400 L3
Re: Changing carbs
As far as I'm aware that should be ok.
Just check if they both have the "Icing" circuit on them or your have to block it off etc
Re: Changing carbs
needles and main jets may differ. If so fit the ones from your original set.
- CaNsA
- My Bike: ZX6R F1
Re: Changing carbs
Also, might be worth checking if the are both either 30mm or 32mm carbs.
The ZXR400 UK model has 32mm carbs, some of the JDM L models have 30mm carbs.
Re: Changing carbs
Nice one folks. Gotta ask tho wat is the icing circuit?
- Miles
Re: Changing carbs
Coolant hoses that run along the back of the float bowls. There too prevent carb icing
