Im looking for a quick action throttle as having to take a second grab at my throttle is frustrating .
ive found some information on another 400 forum and some say a single cable one will be okay and others say it will jam open so say you need one with the return cable
if anyone has a link to one they have personally used and any fitting tips would be ideal
thanks
scott
Recommend me a quick action throttle ?
- My Bike: zxr400 L-9
- My Bike: ZXR400
Re: Recommend me a quick action throttle ?
i know some people have used a motocross throttle as they are quicker action.
- My Bike: Zxr400L racer
im running a venhill qa throttle and only using one cable, had no issues with jamming, as long as your carbs are clean and the return sring is free moving it is fine
Thanks for the replys
Which model did you use from venhill and was it a road bike if so what did you do for a switch pack ?
I use a GPz900 switch gear on mine - direct plug n play
Think it's a CR250 throttle tube you can use to make a stock one quicker action , NSR250 might be another option too.
Just ordered the cr250 tube , have to look in to the switch packs now so a cr250 tube fits with the gpz900 pack ?
Was comparing it to the zxr pack and they look very similar
Right
I got my cr250 tube and have modified it to fit 100% in the original switch pack !
In turn it gives a 1/4 ish turn throttle and is running the original cables aswell so all standard gear minimal messing
Due to it being a mx based tube you have to drill a 22mm hole to open the end of the tube and cut a small wedge out of the cam where the cable buts up , also how much you remove here may have an affect on your duration
Then I had to sand down the top as it very slightly caught the casing and now it's in fitted 100% OEM !
Once in you have to remove the plastic guide for the return cable which you don't use anymore anyways as the new bigger cam needs this space
The last one is a video if you clic the pic and takes you to the video
Depending on how it works out I may make some up and sell them for £35 to your door and will take me pics tommorro when I put the bike back together
