Swapped engines but new lump has no carb heaters ?
spudboy6
My Bike: zxr400 L-9
Post by spudboy6 »
I've just swapped my engine as my one had a bottom end gone
So my bike was a l-9 with carb heaters , the new lump must be an early model that doesn't have the outlet for the carb heaters on the block below the inlets next to the stat housing
Can I just fit my original carbs and block the heaters off ?
Any help would be great as I would love to get that lump in !
Re: Swapped engines but new lump has no carb heaters ?
Yes
Just blank off the plumbing in the cooling system...............if you like you can remove the piping from the carbs too or leave it if you wish
spudboy6
My Bike: zxr400 L-9
Post by spudboy6 »
Thanks , out if interest I presume now all zxr409 had the carb heaters so does that mean there is a special longer water hose available for it ?
Checked the L3 parts pic and there is REF3062f
But no info in the price grid below its not even mentioned ?
dunno.................not something that was ever of a concern to me
spudboy6
My Bike: zxr400 L-9
Post by spudboy6 »
I popped in to kawasaki and they told me that pipe was discontinued
So now to block it up thanks for the help anyhow
