Hi guys,
I bought a zxr400 L1 a few weeks ago, but I can't get the bike running. I changed the fuel pump, cleaned the carbs and air filter, changed spark plugs, and now the engine dies if the air filter is in. So definitively, the mix is too rich. I set the air screw from 1.5 to 2.5, but still not working. Again, If I remove the air filter, the engine just works fine. My mechanics does not have any idea on what's going on...
Any idea?
Thanks!
Dies when idle, works fine without air filter
- My Bike: zxr 400 L
- Restricted
- My Bike: zxr 400 l6
Re: Dies when idle, works fine without air filter
Is the airfilter clean? I cleaned my k&n and then over oiled it, other possible cause is that the air jet is blocked, take off the plate the airbox mounts onto and check that none of the 3 jets are blocked, I had some silicon that I used to seal the airbox drop in, took me 3 days to sort it
- My Bike: Zxr400 H1
This happened to mine as i was rebuilding it. All i did was take the air box completely off and let it idle up to temperature then gave it some good revs up to near the redline, put the airbox back on and it worked fine. might just have some blockage somewhere.
- Restricted
Also try riding it, my bike would idle like a dream when I had the air jets blocked but as soon as I took it out it wouldn't run properly
- My Bike: Kawasaki ZX400G
I'm busy tuning my carbs after a mechanic screwed it up and I run into that situation once in a while. Make sure your float levels and pilot screws are set correctly. Mine dies when its too rich on either of them.
