whats your zxr wieght??
xlr8_07
- My Bike: zxr400 h1
chucked mine on the scales last night and im down to 138kg (304.2lbs) full of oil and with an extra large radiator full of water
- deviant
- My Bike: ZXR400 L3
Re: whats your zxr wieght??
nice work. so what have you put in the bin then?
- jake
a h1 at that weight??!
is that with carbon wheels/fairing/ everything?!
cbr chris
xlr8_07
every single bolt even the fairing and brake bolts has been drilled, total loss with the cdi under guage cluster for less loom ( cluster made from aluminium as well ) no starter, drilled every unnessacery pice of weight off it how ever i can still shed a bit from rear tail assy, no flywheel, even has a 190 rear wheel ( + in weight
) light weight farings, no airbox etc, skimed foam from seat, all casting slag removed, aluminium blank sproket, braded lines including rear suspension res line ( havnt fitten this shock yet how ever ) light weight prosport LITE temp guage .... it seriousley just keeps going
i said id shed pounds before gaining power ( thus giving me time to get my exp up - im determend to build a 444 eating 400 )
yea i know by now your just thinking another :wanker
but i am dead serious
- deviant
Good stuff.
I need to remember to weigh mine at some point, as it's in standard trim for what is probably the last time. Need a reference weight to see how much the stuff I have planned saves.
I think I'll probably pass on drilling the brake bolts though
xlr8_07
lol, they were done bythe guy before me and he ran 2 seasons ( even 3 races with 444 kit - then snaped a rod
) with them drilled and didnt have a problem, they havnt got much taken out, i beleve is 4mm from a 10mm bolt, all the rear suspension bolts and engine mount bolts are done too
lol but the bigest saving was the swing arm bolt
- wonderpupp
- My Bike: ZX6R P7F
That's all nice, but how much do YOU weigh?
I lost about 10kg in weight last year and all my bikes were faster
But I did hae to buy lots of new clothes and leathers though..
Anyone else notice how Rossi is now wafer thin (like a waif!) on the 800s now, compared to his muscliness on the 990s? That's dedication. Mind you, looks like his best mate Ucchio to eats all the pies now!
- crushedlizard
- My Bike: ZXR400 L2
Jesus that's like an RS125 with twice the power!
xlr8_07
i wish it was
115 kg man imagine that!!!! im currently 78 -80kg ( depending on if the roast from the night before has errr you know
) but being 6ft my leathers are quite heavy .... short people say they have the disadvantage in life
xlr8_07
also going to try going back to an h model radiator for the winter series ( cold days any way
- jake
get rid of the h1 swinger if you havent already. Put a h2 one on, big weight saving there
WelshD1K
nah he has a h1 thats been 'slotted' for larger rear tyre
xlr8_07
not allowed for post classic rules, not allowed to change any major components from factory originals, hvae niped a few of the supports out from the front of the swing arm
raul
- My Bike: zxr400
138kg ? wow mine at last MOT was 97x2 all fluids and 1/2 tank of fuel , all std. road bike , i find it hard to imagine how you managed to loose around 50kilos and retain steel wheels
