Pressure Data
Rasta-ninja
Pressure Data
Post by Rasta-ninja »
Hello! its a long shot i know, but does anyone have any cylinder pressure data(for any motorbike engine) that i could have? the higher it revs the better :P would really help out with my dissertation, thanks!
Top-shaggy
My Bike: KR-1R
Re: Pressure Data
Post by Top-shaggy »
I'm a bit dim but would like to help where I can..
Cylinder pressure data?
Do you mean compression ? Or compression ratio ?
Or something else like the pressure a cylinder can hold before it fails ?
winks
We are we're we are..
Rasta-ninja
Re: Pressure Data
yeah sorry didn't really specify!
Nope not compression, the data i need are cylinder pressures of a running engine(ignition) at different RPM's, in other words what the pressures in the cylinder are over 720 degrees(per degree) every 500 or 1000 RPM, max RPM only matters really though,
its usually in an excel spreadsheet and the kind of data you need special gear to collect, so was just seeing if anyone on here has been involved with anything and happen to have some data they wouldn't mind sharing,
like i say its not likely, I'm sure some people here have track data for suspension travel, acc, vel etc but was just seeing if anyone has any engine stuff
kawizard
Re: Pressure Data
Post by kawizard »
Swansea student?
Rasta-ninja
Re: Pressure Data
Swansea Met yes, only the best ;) haha i'm guessing you came here as well then?
