Can somebody please tell me where this goes?
				gargarzxr
 - My Bike: 92 zxr400
				tobomoto
 - My Bike: zxr400l4 zx7r
Re: Can somebody please tell me where this goes?
im guessing its to do with the oil mate. lift the tank and have a look in the radius of it to see if theres a connector on the main loom.
Oil ! LOL
Its the ignition pick up goes to a green connector up near the battery right hand side. At least I think its green nearly certain
				tobomoto
I was gonna say that next. Honest...
				mongo
Aye, im sure its right beside the indicator relay. It routes through the clutch cover theres a little metal bracket, usually its riveted with a plastic connector between the clutch plate and the casing inbetween the gap and up over the top, then over the spar on the frame then onto the subframe.
Ok all you experts there are a couple of other things in this picture that are missing..................and potentially engine wrecking
Anyone else see it or am I blind ?
- CaNsA
 - My Bike: ZX6R F1
Something black, touching something shiny....?
Looks like he might be missing an oil pipe?
- CaNsA
 - My Bike: ZX6R F1
I really cant see it.
Put us out of our misery Cargo
				gargarzxr
Right so now im even more worried. fill me in cargo im only a learner
				gargarzxr
At least I've got your attention now.....................
Where is the clutch cable ? And heres the important bit where is the little bracket that supports it ?
It's the little bracket held in place along with the dreaded cam chain tensioner.......................................................cue dramatic music
Yes folks it's that old Cargo favourite......................................DA DA DAAAAAAAAAAAAAAAAAAAAAAAAAAAAa
				gargarzxr
good eye
  The cable was just out of sight i have the bracket mounted now. Why is the cam chain tensioner dreaded?
AHHHHHHHHHH so you removed the clutch cable bracket...............that means you removed the two bolts that hold it AND the camchain tensioner.
do tell how did you refit the bracket...........? ?
