Compression tester & whats this?
Symon
My Bike: Ugliest Zxr 400 L5
Post by Symon »
Hello, Just a quick question. What size adapter do i need to do a compression test?
And while taking the bike apart i found a tube leading to the carbs, but someone has blocked the other end with a nut.
Whats it for?
CaNsA
My Bike: ZX6R F1
Re: Compression tester & whats this?
Post by CaNsA »
Does that goto the carbs or the airbox?
Looks like a breather/drain to me.
Take the bolt out and see what comes out.
I reckon a watery/oily gunge.
Symon
Post by Symon »
Yeah it go's to the carb, I took the bolt and a little drop of fluid come out. It smelt abit like petrol but was oily. And do you no what size adapter i need for the compression tester?
Thats looks more like the carb heater circuit to me.
Danman109
My Bike: ZXR 400 L9 2001
Post by Danman109 »
agreed, looks like carb heating,
This tube just runs warm coolant through the carbs to keep them warm in winter and helps to prevent carb icing.
i've blocked mine off both ends and removed the rubber pipes with brass looking connectors because it makes it easier to fit and remove the carbs + i wont be taking it out in winter so im not gonna get carb icing!
ZXR 400 L9 race bike
ZXR 400 L2 Hopkins GP replica.
