You have tried charging the battery, haven't you?banner001 wrote:its an odd one, the starter motor turns, but i fair mashed some of the carbon brushes trying to get the commuter bit in, the solenoid, when i depress the starter buton makes a loud click, then makes another click when i release the button. have ordered replacement starter motor. the starter motor turns over, i removed the generator cover to look at it, but it soesnt sound like its turning the motor over, just makes a kind of grinding sound.BigB wrote:Sure it's not the starter relay? I had a similar problem with my scooter
fuel pump is working and the rest of the electrics are ok, the 30A fuse in the starter relay is fine and there are no fuses blown in the junction box...
If it's showing less than 12v it's probably buggered. I've had them do exactly what you describe when they're shagged. (not literally! I'm no pervert!)
