throttle cable
alanh496
throttle cable
Post by alanh496 »
Hi, I'm looking to make up a longer throttle opening cable to allow me to change the position of the clip-ons, and I need the plastic adjuster that takes the cable round an angle inside the twistgrip - would anyone have a knackered cable that I could take one from ?
R P Corse
CBT slow
CBT slow
My Bike: ZXR400 H1
Re: throttle cable
Post by R P Corse »
speak to venhill about cables mate, they can make one up for you at whatever length you want/need
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: throttle cable
Post by Mori Man »
GPz900R will fit but think a few other models also use same set-up too. With the GPz cables you will get screw n locknut fitting at the carb end, np to use on CVKs but excellent for FCRs :smt003
BTW, GPz are longer
GPz \ GPx 600R should be another option but slightly shorter than the 900s and have the normal end fitting to the CVKs on them.
